I have a scene with two side by side objects to which to apply two different serigraphy. the first serigraphy of the object on the left is applied correctly. when I import the second serigraphy and try to apply and position it on the object on the right, the serigraphy also appears on the left object (the same serigraphy is partially repeated on the left obj too).
I’ve tryed to create a new keyshot scene with only the object with the new serigraphy and that’s ok.
…but when I try to join the two scene importing the second BIP keyshot file to the first, Keyshot always crash.
mmmmmmmm
little help ?
thx
It sounds like you’ve linked materials which happens if they have the same material name in the original software. So before applying the serigraphy select the second object and click ‘unlink material’. Think that should help.
The crash of KeyShot shouldn’t happen of course but maybe it’s caused by conflicting materials or their names. Support is always interested in scenes that make KeyShot crash since those help to solve stability issues which can be hard to reproduce. So if you’re able to share the model, it helps if you send it to the support team.
Perfect,
grazie Oscar!
p.s.:
Following the crash, Keyshot on next boot detected the problem and offered me to send the application crash data. I agreed.
